First post, by sptsprsn
I love the aforementioned game, and I am using DosBox to play it, but I am having a problem saving the game. There is a directory mismatch error.
I have run the set up and tried to change the directory, but when saving the game the directory for the save file is not the same as the directory I provided.
I also tried to set up the directory that the save function tells me that it is trying to save at, and that has not worked either.
Thank you for any help possible.
