First post, by TheFunkyShmoo
Hi there,
I'm looking for documentation regarding the command line utilities that are included with DOSBox, and specifically what command line arguments these utilities support. Does anyone know where I can find comprehensive documentation on this subject?
The specific question I'm looking to answer is how to control the sort order of the DIR output. In MS-DOS, this would be accomplished with the following command:
dir /o:x (where x is the desired sort order)
1. Does the dir command included with DOSBox support manipulation of output sort order? If it does, what is the relevant command line syntax?
2. If this behavior is not supported by the DOSBox dir command, what alternatives do I have within the framework of DOSBox environment?
I appreciate any assistance.
Bill
