First post, by eL_PuSHeR
Hello.
I guess not but no hurt in asking. I am thinking about migrating to Win7 x64 because 4GB+ of RAM is becoming common trend nowadays.
Reply 1 of 9, by gulikoza
There is no problem running win32 console apps as long as they truly are win32 apps and not using any 16-bit stubs.
http://www.si-gamer.net/gulikoza
Reply 2 of 9, by keropi
Not really an answer 😁 personally I've been on 64bits some years now... if you have an older pc around it will be handy if you mess with ancient stuff, else vmware is great, a simple win2000pro VM has been useful to me several times... but it depends what kind of interoperability your programs require...
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
💾💾💾 Looking for a full version of LIST ENHANCED 2.4y1 by V. Buerg, message me if you have it! 💾💾💾
Reply 3 of 9, by eL_PuSHeR
Thanks. The app. I am talking about is Image Alchemy (alchlong.exe). I think it's a 32bits PE executable. Don't know about 16bits stubs though.
Reply 4 of 9, by keropi
is there a demo somewhere to test? I can report immediately
edit: it runs fine, win7/pro x64:
Reply 5 of 9, by eL_PuSHeR
That's weird. Last time I tried it failed.
Thank you very much.
Maybe I ran alchemy.exe instead by mistake.
Good to know.
Reply 7 of 9, by eL_PuSHeR
How do you invoke it?
Reply 8 of 9, by collector
You start it like you would VPC, but once you install an application in it, you will find a shortcut to it in your Win7 Start Menu that you can use to start it as if it was an application running natively in your Win7, but with an XP style window. I also also able to use it for my old scanner that had no 64-bit drivers by installing the drivers in the XP VM.
Reply 9 of 9, by eL_PuSHeR
Great! Thanks.
