First post, by Robin4
Its it possible to use a Evergreen upgrade 486 processor in een blue intel overdrive socket?? Or can it only placed in normal sockets?
Reply 1 of 2, by Robin4
somebody?
Reply 2 of 2, by DonutKing
Try it and see? The Overdrive socket is just a standard Socket 2.
Not familiar with the Evergreen upgrade specifically but as long as it has a voltage regulator on it to accept 5V it should work - assuming the BIOS likes it. I've had a couple of boards that don't like my Kingston Turbochip 5x86 upgrade, until I upgrade the BIOS.
