First post, by Fexel
Hey there,
I need 16bit colors in Win 3.11. I can choose it but it tells me too little ram. How can i fix that? 😀
Bye
Reply 2 of 11, by Fexel
Dominus wrote:
look in your config file 😀
Sry, this doenst help me.. Some more Details im not THAT Expert u apparently think i am 😉
Bye
Reply 4 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
choose a lower resolution when selecting the 16 bit graphics ?
Water flows down the stream
Reply 5 of 11, by Fexel
I choose 640x480 for 16bit.
About dosbox.conf - This is not a problem for me. But my changes didnt helped me out. memsize set to 64 but no positive effect. THATS why i asked here so please help me 😀
Reply 6 of 11, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Ok, then back to the start.
First make sure you edit the right config. The default config is no longer called dosbox.conf. On start the console window will tell you which config is getting used. Try a clean config file (I think on Windows you have a dosbox start menu item that resets the config).
Tell us which graphics driver you are trying to change in Windows 3.1x
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 7 of 11, by Fexel
A little bit arogant he? -.-
I use special .conf Files for every installed Application! It was only a example!
I will use this one:
S3 864 1.41B5 640x480 16.7M colors
I can install it but only with the message, that i have now too less memory and some icons had to be changed into blank symbols.
Reply 8 of 11, by Dominus
DOSBox Moderator
not arrogant, but fed up with people asking for help but not revealing what they are doing from the start.
When I say "look in your config file" and you reply "Sry, this doenst help me.. Some more Details im not THAT Expert u apparently think i am" you are leading one to believe that you have no idea how dosbox works or that there even is a readme.
But when you are such an expert after all, then are you SURE it is using that config file? AND, most important, try a default config file OR post the contents of your special config file for Windows.
Reply 9 of 11, by Fexel
Hey, u dont know me. So dont tell me what i am and what not. I will look for help somewhere else.. dont like people who are so prepossessed.
THX for your time,
bye
Reply 10 of 11, by Dominus
DOSBox Moderator
bye bye (just a friendly reminder, when you go some other place, make sure to include as much information as you can and when someone tries to help you don't call them arrogant (since I'm not even sure where the arrogance was there)).
Good luck
Reply 11 of 11, by wd
Rank DOSBox Author
DOSBox Author
That's why YOU have to provide relevant qualified information in the first place.
