First post, by golencio
Is there a way that makes DOSBox interact with windows 7 programs? In fact, I want to send a document from DOSBox in .pdf format via email.
In Windows XP I was able to do that becouse I was running my DOS program, and from there I was able to run a Windows program (DOSPrinter) that converts my DOS document in .pdf format and sends e-mail via Outlook Express.
Now with Windows 7, I can't find a way to run a Windows program from a DOSBox line. Can anybody help me?
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
DOSBox is not designed to do that. It's intended to run games.
You could probably create a bat file which does something like this:
dosbox myprogram.exe
if exist document.pdf mail document.pdf
if exist somethingelse do something else
Water flows down the stream
Reply 2 of 5, by golencio
Hmmm.. no, I can't start a mailing program from DOSBox...
Reply 4 of 5, by golencio
This would be great, do you have any suggestions about the "monitoring" program?
Reply 5 of 5, by Jorpho
Googling for <windows "directory monitor"> should get you started.
