First post, by keropi
- l33t++
Hiya!!!
I have noticed that I am having interference in my vga output when I first boot up my p200mmx/win98SE machine that has a voodoo2 in it (some diagonal faint lines) but all that is gone after I go once to the voodoo display properties tab and the internal switch does a cycle.
Is there a way to make said fake switch cycle with a command or a registry entry?
Also any ideas what's causing those diagonal lines that disappear after the signal switching? Maybe I need to better ground the v2 or something?
thanks in advance for any info! 😊
