sliderider wrote:What's special about the SiS board apart from the fact that you don't have one?
There have been successful reports of some SiS PCI boards with a working Voodoo3 graphics card. Some SiS boards also seem to work with 60/66 MHz front-side buses. The screens of UMC-based PCI boards won't turn on with a Voodoo3, Banshee, or TNT installed. The issue with using a UMC board and a Voodoo1 or 2 is that a second graphics card is needed for 2D graphics. On 3-PCI motherboards, that leaves only one extra PCI slot. I prefer to run systems with a PCI SCSI card and a PCI network card, which isn't possible with a Voodoo 1/2, however it would be possible with a Voodoo3 (as it has 2D/3D on one card).
While I am happy with running a Matrox Millennium G200 for 2D/3D on my UMC-based 486, I am wondering if a Voodoo3 3000 PCI could squeeze out any added performance, and compatability, when mated with an IBM 5x86c-133/2x. I beleive the SiS boards at least have a 1:1/2 FSB-to-PCI divider, which would make using a 66 MHz FSB a possibility.
For those with a good 486 SiS PCI board, would you mind running the following benchmarks using a Voodoo3 300 PCI, 512 KB WB cache, 64 MB RAM (or 256 KB WB cache and 32 MB RAM), and either an IBM 5x86c-100/120/133, AMD 5x86-133/160, Intel DX4-120/133, or POD-83/100:
DOS
Symantec Sysinfo v8.0/8.1, PiDOS (75k digits), Landmark v2.0, Bytemark v2-32-bit, Roy Longbottom Dhrystone v1.1 (dhry1od), Roy Longbottom Whetstone (whetcod), Speedsys v4.78, Cachechk v7.0, 3Dbench1, 3Dbench2 ver 1.0c, Doom 1.9s timedemo 1, Pcpbench VESA Modus 100 640x400, Quake1 Timedemo 1 (320x200 & 640x480, console off)
Win98SE
SuperPi v1.1 (128k digits), Ziff-Davis Winbench96 CPUMark32 and Graphics Winmark, Ziff-Davis Winbench99 FPU WinMark99 and CPUMark99 (Stand-alone program), Ziff-Davis 3DWinbench97, WinTune98, Sandra99 (CPU, Multimedia, Memory), PassMark v4.0 (2D Graphics Mark, Memory Mark, Math Mark), 3DMark99Max, Final Reality v1.01, MDK Performance Direct3D/Software, and Quake2 (640x480 - Software).
The reason for listin some non-graphic type tests is to get a good idea for how well your SiS system is performing on the CPU, RAM, and cache side of things. For example, if our CPU, RAM, and cache performances for the SiS board are on par with those of my UMC board (given the same CPU), but your SiS/Voodoo3 system does much better in Quake and other graphic tests, then the Voodoo3 might provide some benefit over the Millennium G200, even though both systems are CPU-limited. This is my motivation anyway. I'd also like to know if the SiS board can handle a TNT2.
dirkmirk wrote:I can run some tests if your interested, in speedsys my pci bandwidth with the the Voodoo3 is only around 16,480kb/s...
Some forum members have questioned the accuracy of Speedsys' video performance test, so I think it is a good idea to get a sample pool of benchmark results (list above).
Yes please!
dirkmirk wrote:Im hoping to get an ALI PCI chipset board working that will be an interesting comparision.
My one encourter with an ALi PCI 486 board wasn't the best, but that's just one board. I look forward to your results, perferably with the above listed ensuite of benchmark programs.
