First post, by yardape8000
When you set a new key map using:
config -set "sdl mapperfile x.map"
should it not reload the map?
commands like this update instantly:
config -set "cpu cycles=10000"
thanks
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
Not all commands work.
The mapperfile might indeed not work. I don't think any of us bothered to implement it.
Water flows down the stream
