Turbo Pascal problem
First post, by Kirirus
A simple program
Uses Graph; Var GD,GM:integer; Begin GD:=VGA; GM:=2; InitGraph(GD,GM,''); CloseGraph; End. […]
Uses Graph;
Var GD,GM:integer;
Begin
CloseGraph;
End.
does not work...
Reply 1 of 6, by wd
Rank DOSBox Author
DOSBox Author
Works fine, assure that the bgi drivers are present and stuff.
Reply 2 of 6, by bloodbat
As WD said, you're probably missing the .BGI file in the same folder as your executable, just out of curiosty add
cleardevice;
after initgraph and before closegraph
and
writeln(graphresult);
after closegraph and before end. so you can see what (if anything) went wrong as a numerical result since, at the moment, it's doing nothing and it might indeed be working and you're just simply not noticing (on exit TP restores the CRT mode and it exits right after closegraph; if you want it to wait, add
readln;
after cleardevice, so you can see your wonderful black graphics screen).
Reply 3 of 6, by Kirirus
The BGI file is present... When I trace the program with F8, it works normally, when i try to start it with Ctrl-F9, DosBox window immediately closes.
System is Win7, when I used XP, all programs worked normally.
Reply 4 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
ctrl-f9 is the key shutdown dosbox
Water flows down the stream
Reply 5 of 6, by Kirirus
This is zip with program and TP.
Reply 6 of 6, by Kirirus
😀 😀 😀 Hah!
Thanks!
