Simearth being dificult
First post, by Zelda0909
😕 Im kinda new but I've played wolf and lion alot before.
Okay so heres the problem. I type in all the codes then loadfix then I try to start the game and it says that it doesnt exist. I put in C: and everything but it just wont work no matter what I try!
Reply 2 of 8, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
You should check the 60 seconds guide at the Guides Section.
Reply 3 of 8, by Zelda0909
mount c c: / (No space)
c:
loadfix simearth
cd simearth (Sometimes this wont work either)
simearth
then it says illegal command. 😕
I put the file in the C: place on my computer and called it simearth
Reply 5 of 8, by Zelda0909
yes thank you for that but I already knew all that thx.
Reply 6 of 8, by bloodbat
If your commands are sequential...you're doing it wrong...
cd simearth should go before loadfix simearth; are you sure simearth is an .exe or .com or .bat file?
Check what's the proper command to start the game; if it's a .bat file...check that whatever it references is actually there.
Reply 7 of 8, by Zelda0909
its says it a .dat file... I've never even heard of a .dat file! cd simearth doesnt work if I dont do loadfix simearth.
Reply 8 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Then there is something wrong. please try to follow the 60 seconds guide, especially the part with the dosgames folder.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
