First post, by sepultribe
I apologize if this has been discussed before, but I found a SB16 CT2910 ISA card with the original YMF289-B OPL3-L as the seller says. I currently have a CT3670 and i've read that it doesn't have a real OPL and is quite noisy too. Is the CT2910 a good replacement? thank you
