Problem loading games
First post, by blackspaven
Hi,
Just started looking at playing some old skool games from my youth and after not understanding how dosbox worked after i'd downloaded it, I kinda worked out to download & successfully use d-fend reloaded which seems to run dosbox inside it (haven't a clue,... it just works!!) and although I get a few games which seem to work such as Eye of The Beholder 2 and Cannon Fodder, the majority of games i've tried to download and play using this don't seem to work and I have no idea why not, no matter which sites you try to download from?
In d-fend, when I click on the games which don't work (eye of the beholder being a particularly annoying one since the sequel is fine!), it appears to load up but at the point where the working games start to play, it just returns to my normal laptop front screen as if i'd done nothing. Wierdly, Syndicate appears to load up, show the start sequence, but then kicks back out like the others when you click to try and play.
Any ideas on what to do to get them to play (I've read guys on here who've played EOB but without sound, so it must work to a point?!), as i'd like to play the full EOB series, expecially since i'm bedbound after an operation on my knee and I need something to cure the boredom!
Reply 2 of 8, by blackspaven
Okay, so you've got to understand i've know less than nothing about how this stuff works: i've only ever chucked in a disc and clicked 'start' or let it autorun to play a game or programme.
I managed to follow the guide enough to change the 'mount' so it shows the folder in which the games are stored, but I have no idea how you start them to play them. The manual didn't help as I didn't understand what it was saying. That's why d-fend was easy cos you just drop the zipped file in the frontscreen box and double click it.
So how do I select the game?
Reply 3 of 8, by blackspaven
Oh, and the games are downloaded, NOT from an original disc.
Reply 5 of 8, by blackspaven
Didn't know they're pirated. How can they be so easily accessible with them being on the first 10 pages of any search when one is just looking for screenshots?! I believe them to be abandonware.
Reply 7 of 8, by blackspaven
I didn't think it was pirating if you already own the game?? Just stuck in my loft somewhere, but i'll be buggered if I can be @rsed to look for it!
Now that I believe we've got that out the way, how about some helpful tips, dad??
Reply 8 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Grab the original, apart from legal issues there are other issues with crap abandonware. If you own dos games, did you never play them back in the days? Dosbox works similar.
Read and follow the 60 seconds guide and don't use a frontend if you don't understand how those work.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
