First post, by djcolomb
Hi! I'm looking for cm2fix.zip file! It's a patch to make cm2 run successfully through Dos Box. Anyone who can help me?
Thanks in advance
Alessandro
Thanks in advance
Alessandro
Or use the search 😉
Searching for cm2fix leqds you there as well 😉
wrote:Or use the search 😉
the site changed location http://pferrie.tripod.com/
Thank you very much! But now how does it work? I can simply open the new fixed file through dos box, or do I need do mount the cd (original) through dos box and then execute the fixed file?
mount the CD like you would normally, but run the cm2fix.com instead of cm2.exe.
