First post, by lukeluke
Hi,
i am totally new to this forum. I wanted to try Another World on dosbox, but after entering the code, a blank screen appears and nothing happens!
Is there a way to make it work? I am using d-fend with dosbox 0.74
Thanks
Reply 1 of 3, by Jorpho
The 60 Seconds Guide is always the place to start.
60 seconds guide to getting your game to run in DOSBox
Also, you should be aware that if you just downloaded this game "for free" from somewhere (as opposed to installing it from the original disks), then your copy may very well have other problems. GOG.com sells a very nice version of the game that you can buy very cheaply and that is very unlikely to have any problems.
Reply 2 of 3, by RacoonRider
There is also a remake with almost original graphics, you may want to try that.
Reply 3 of 3, by bloodbat
That's the version GOG sells, you can choose from the original graphics or the redone ones.
