Tie Fighter CD
First post, by Stryker412
I have the DOS versions of the Collector's editions. I used DOSBOX and I now have proper graphics/sound. Problem is now I cannot get my USB gamepad to properly calibrate. I am using an old Gravis GamePad Pro. I go through the calibration at the start of the game but I cannot move the stick anywhere but down right. Any ideas what DOSBOX settings I need to change?
Reply 1 of 3, by bloodbat
If the joystick is detected by Windows (assuming that's your OS, since your post lacks info) AND DosBox; try changing the timed value from true to false...
Reply 2 of 3, by Stryker412
Yep thanks that worked. Now just need to get the graphics working properly. Right now it's extremely low FPS.
Reply 3 of 3, by bloodbat
Again, you're lacking information, but increase the cycles.
