First post, by exofreeze
- Member
Mounting a bin/cue image of Actua Soccer.
Install starts up, I select language, I choose to install game, then it says "divide error" and prompts me to press a key at which point it returns to the main install menu.
Using default conf values with cycles set to 50,000
I wasn't sure if it was the version of dos4gw, so I unpacked my bin, replaced with with a renamed version of dos32a, repacked the bin, and tried again - but got the same error.
