First post, by exofreeze
Using bin/cue image, the install will create the BH95 folder and then claims the install is complete, however no files are copied over.
I have tried 0.74 & SVN. The debug version repeatedly says "null write" after I hit install.
conf file is set to defaults.
Help is greatly appreciated.
Reply 1 of 4, by Jorpho
Just in case no one posts a fix, you might be able to get it to work by booting a hard disk image in DOSBox. You'd probably have to copy the bin/cue to the image and mount it using SHSUCDHD.
Reply 2 of 4, by exofreeze
Thanks for the suggestion. In a worst case scenario there are rip versions floating around I can use. I would just like to install from this original cd image.
I'm not 100% familiar with booting hard disk images or using SHSUCHDH
Reply 3 of 4, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The installer needs XCOPY in the path. You can use XCOPY.EXE from MS-DOS or FreeDOS; however, no special switches are used, so in this particular case you can create a XCOPY.BAT file with the command "COPY %1 %2" and put it in the path.
