First post, by exofreeze
Attempting to play Goal! in dosbox (0.74). Everything works great up until it prompts me to press the fire button on the joystick to start the match (or practice, or whatever).
I have disabled the joystick emulation in the conf, but this did not help. I also checked the options and could not find a way to opt for keyboard control.
Any suggestions? Thank you.
Reply 1 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
If you look in the TEXT.ENG file, or any of the other language files, it appears there are only options for JOYSTICK1 and JOYSTICK 2, nothing like KEYBOARD or MOUSE, so appears it does need a joystick. If you don't have a joystick, you can create a "joykey" setup in the DOSBox mapper by mapping keys to joystick movement (like a d-pad, obviously not analog) and buttons.
