Ultima 6 save problem
First post, by L.T.Stone
Hi guys , I am trying to play Ultima 6, Martian Dreams , Savage Empire on my Gp2x Wiz through Dosbox but it won't save properly, now doing a search I found that this fellow : Ultima 6 saving issue
found a solution but I don't understand exactly what he did is there anyone here who understands and could help me out?
Thanks
Reply 1 of 5, by Jorpho
Why did you start a new thread instead of just replying to the old one?
This is evidently a problem with the unofficial, unmaintained GP2X port rather than with DOSBox itself.
Skutarth wrote:
Here's how I mounted it for it to work:
umount /mnt/sd
mount /mnt/sd -t vfat -o rw,sync,noatime,check=r
These are shell commands that you will have to execute on your GP2X before running DOSBox.
Reply 2 of 5, by L.T.Stone
Duh, I guess I could have replied to the original topic..
Thanks for the info , Now I just have to figure out how to do this..
do I run it through a terminal or dosbox config or more likely write a script somewhere, I'm not the smartest guy for sure.
I know this is a problem with dosbox itself , im just trying to get any solution to run these games.
Reply 3 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
It's not a problem of Dosbox, it's a problem of the GP2X port of Dosbox. The last version of this port is over four years old...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 5, by L.T.Stone
Srry thats what I meant , a problem with Dosbox on the GP2X Wiz.
Reply 5 of 5, by Jorpho
They're shell commands, so they are entirely independent of DOSBox. If you need help executing shell commands, you should probably ask on a GP2X forum.
