First post, by exofreeze
Dosbox 0.74 and SVN from last week tried.
Using standard cong file. Have tried disabling ems/xms/umb
The game supports either pcjr/tandy or cga graphics. If the conf is set to pcjr or tandy, I hear music but see no intro screen. If I use cga, I can see the intro screen.
If I hit the fire button to start the game on pcjr/tandy (w/ pcjr selected as machine type) I receive the error
result=20
You must have the original disk on drive A: to execute this program!
I have mounted my game files to a separate folder as a floppy A:
Using the cga machine type it simple exits back to the dos prompt with no error message.
Using the debug version of dosbox I see it saying disk 0 not active, very similar to the situation with Under Fire in which ripsaw wrote a small TSR that bypassed the issue.
I attempted to use that TSR here, however it did not solve the problem.
Thanks for any help.
Reply 1 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
There is some problem with PCjr, but it works OK with machine=tandy if you select video option 2 in the setup program.
Similar to FaceMaker, mounting any floppy image as A: seems to make the game happy.
