First post, by exofreeze
- Member
Installed ESPN Baseball Tonight from bin/cue image made from my cd.
I had to give it xcopy as the install failed to copy many files over.
Starting the game launches a setup which allows the choice of svga card and sound card. The s3 series cards come back showing a proper display test. I also tried the et4000 setting in the conf file and the et4000 selection in the setup and got a good return on the test.
Once the game starts I get several company logos, however the main menu is a garbled mess with both the svga_s3 and the svga_et4000 settings (each with it's own card selected in the setup).
The above is how the main menu appears.
