SB Live! CT4830 issue
First post, by RacoonRider
I have a weird issue with this PC: My Pentium MMX gaming rig
It sometimes hangs up while Windows 98SE starts. After the boot screen, I see autoexec.BAT starting things and then it hangs up. Happens about 20-30% of the time. Recently I discovered, that it never happens without SB Live! audio card.
I heared that EMU 10K has that weird PCI bus behavior, can this be an issue? How do you fix this?
Reply 1 of 2, by elianda
Even though the SB Live! has some unusual PCI bus behaviour it shouldn't be a stability problem on a 430HX chipset, it probably just slows down the overall PCI transfer rate.
So it might be some other driver incompatibility. So the driver loading bootlog of Win98SE doesn't tell you anything?
Youtube Channel
Reply 2 of 2, by swaaye
Try running with only the Live! and a video card. If it's still unstable, try moving the Live! to another slot.
