First post, by exofreeze
- Member
Installed Alien Trilogy in 0.74 using an IMG of the cd.
Install worked fine, however once I try to launch the game it requests that I insert the CD.
CD is obviously mounted properly, otherwise I could not have installed the game from it.
So this leads me to believe it is a DRM issue. Suggestions?
I see others have run the game with no mention of this problem, which leads me to believe there is either a work around, or they were using a cracked version.
