Running 3dMark 2000 on modern hardware
First post, by kolano
The "3DMark01 Mega Thread" got me thinking about the old 3DMark benchmarks again. Have been trying to get 3dMark2000 going on my nVidia GeForce 580, but am currently unable to.
It starts up, initializes the display, but then drops out with an error...
"3dMark requires a 3D-accelerator with 4MB or more video memory
Please go to MadOnion.com and find the best upgrades for your system or use 3dMark 99 Max"
...which I'm guessing is related to it being confused by a graphics card more than a gig of video memory.
Does anyone know of a way around the check, or to restrict the amount of video memory reported to 3dMark to avoid the issue?
Reply 1 of 73, by pinkdonut666
I've had great success using 3Dmark 2001se on modern hardware, but i have not tried anything older, Though i know if you have more than 3gb's of system ram you will get an error but it's skip able.
my life runs on X86
Reply 2 of 73, by RoyBatty
Hrm, I haven't tried it on Win7, but I did get it working in XP with my 9800GX2, did not try with my 580, so I think it's probably an issue with how much ram the video card has. I don't have my installer handy or I would have a look and see if I can get it to run. It's probably a simple patch to allow it to do so.
Reply 3 of 73, by kolano
Was able to get 3dMark 99 Max running via the instructions here...
http://community.futuremark.com/forum/showthr … l=1#post1281703
...though 7zip will now also extract the installer exe.
Still hoping for a fix for 3dMark2000.
Eyecandy: Turn your computer into an expensive lava lamp.
Reply 4 of 73, by teleguy
I got 3dMark 2000 to work on my 3 GB 7970 by modifying SystemInfomfc.dll. Just put the file into the benchmark directory. You'll have to use Win 98 compatibility mode and accessing the systeminfo menu will result in a crash.
210.67 KiB
    3DMK2000patch.zip
    43.05 KiB
    2130 downloads
Reply 6 of 73, by kolano
Thanks teleguy.
With your patch I no longer get the "4MB or more video memory" error but instead get a similar error "3dMark2000 requires 64MB of memory to be able to run."
Any chance you can further patch it to work around systems with multiple gigabytes of memory?
Reply 7 of 73, by teleguy
kolano wrote:
Thanks teleguy.
Using Windows 98 or XP compatibility should fix that.
Reply 8 of 73, by kolano
Thanks again. I was able to get it running again this afternoon thanks to you, "37700 3D marks".
So the issue was that I'm also trying to run it off of a network share. Apparently the Compatibility Mode settings can't be applied to apps on network shares. I found a few "workarounds" but none of them actually seem to work, which is why I though it was still broken in Win98 mode.
Not sure if anyone has a working workaround. Thus far I've tried...
  • Launching with a bat file that has Compatibility Mode set on it:
    http://www.sevenforums.com/network-sharing/14 … -drive-app.html
    @echo off
    start V:\Demos\Commercial\Futuremark\3DMark2000\3DMark2000.exe
    exit
  • Launching with a bat file that sets an environment variable to set Compatibility Mode:
    http://netport.org/?p=1616
    @echo off
    set __COMPAT_LAYER=WIN98
    exit
    or
    @echo off
    exit
    This seems to no longer work /w Windows 7. Though it might up to Vista.
  • Setting Compatibility Mode for the app directly in the registry:
    https://www.corelan.be/index.php/2009/04/27/f … ws-2008-server/
Since it seems as though it may not be possible, I may just break down to a revised bat that would copy things to a local drive and run them from there though it's not really the approach I'd prefer.
Reply 9 of 73, by kolano
Two other bits of feedback on the patch.
  • The 64Mb texture test fails to run.
  • It would be nice if some additional resolutions (i.e. above 1280x720 and 16b color) could be made available.
Reply 10 of 73, by teleguy
It's possible to apply compatibility mode to apps on network shares through Microsoft's Application Compatibility Toolkit. Actually you don't even need the full Windows compatibility mode, just "GlobalMemoryStatusLie" and a parameter of 1536 for instance should be enough.
kolano wrote:
Two other bits of feedback on the patch. […]
The texture test fails because there is not enough AGP memory. Currently I don't know how to fix that.
Resolutions seem to be dependant on (video) memory size. XP compatibility mode allocates more memory than 98 compatibility mode so more resolutions are availabe.
file.php?id=17139&mode=view
    220.95 KiB
Reply 12 of 73, by teleguy
I managed to remove the restrictions for the texture rendering tests.
    3DMK2000patch3.zip
    593.5 KiB
    1207 downloads
Reply 13 of 73, by kolano
I can confirm 64Mb Texture test now works with my nVidia GeForce 580.
I was able to get an expanded resolution list /w WinXP instead of Win98 mode, but there seem to be a number of remaining oddities...
  • My native 2560x1600x16/2560x1600x32 modes aren't shown.
  • 2560x1440x16 mode is shown, but selecting that mode results in "3DMark could not initialize your 3d Accelerator. Try to downgrade your display settings. DirectX Error Message: Create Device: DDERR_INVALIDOBJECT".
  • The highest 16b color mode that will run is 2048x1536.
  • 32b color modes top out at 1920x1200, which does run at least.
  • CPU test is unable to run in 32b color modes (Though perhaps this was always the case).
Reply 14 of 73, by teleguy
kolano wrote:
I can confirm 64Mb Texture test now works with my nVidia GeForce 580. […]
Same here. No idea why that happens.
Edit: Apparently that's the highest resolution DirectX 7 allows. The only way to go any higher is using a wrapper or replacing the renderer.
https://www.google.de/search?q=directx+7++204 … OOpM8rDPISWgKgM
I think it's supposed to be like that. I'll be able to test the benchmark on a few older systems on monday and see what happens.
Reply 17 of 73, by teleguy
New version with a few modifications.
-system memory checks removed->compatibility mode should no longer be required
-4 MB vram message bypassed in a different way so that the patched SystemInfomfc.dll is no longer needed->settings menu should now reflect the actual video memory size
-all possible resolutions should now be available
    3DMK2000patch4.zip
    593.53 KiB
    3130 downloads
Reply 18 of 73, by kolano
teleguy wrote:
New version with a few modifications. […]
Thanks for your work here,teleguy.
  • Can confirm things now seems to run fine without compatibility mode.
  • All resolutions are now listed. Though it might be better to limit them to those that are 2048px or less in dimention, as the "DDERR_INVALIDOBJECT" error still occurs if attempting to use higher resolutions (i.e. 2560x1600).
Reply 19 of 73, by u1comp1
Thank you very much for the patch !
And you can do the same patch for 3DMark 2001SE? When it starts not written a mistake and did not include compatibility mode?
    46.25 KiB
