First post, by wolf72
I have a Windows 7 x64 computer. In DOSBox, I type mount c: at the prompt, but all it does is show me the help item for the mount command and never actually mounts the drive. I also tried to mount it by typing mount c:\dosgames, which is the folder where the game I want to play resides. I tried running the shortcut with admin privileges with the same result.
Is there something extra I need to do?
Thank you!
Reply 1 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
intro mount
Water flows down the stream
Reply 2 of 8, by wolf72
Never mind. I think I got it.
Thank you.
Reply 3 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
have you ever used DOS before ?
Maybe read up on how DOS works. Or if you don't want to, use a frontend. (like DBGL or DFend-Reloaded)
Reply 4 of 8, by wolf72
I used DOS way back in the day. It's been a very long time. I think I got the game working.
Reply 5 of 8, by IIGS_User
The game called DOS. 😀
Klimawandel.
Reply 7 of 8, by wolf72
The game actually is Test Drive III. 😀
Will 0.74 give me any better performance, like maybe the ability to actually pick what course I want to drive?
Reply 8 of 8, by IIGS_User
First, better compatibility to your host operating system.
Me, I also run Test Drive III within.
Klimawandel.
