First post, by GXL750
Years back, I built for my mother a desktop with an Athlon XP 2000+, 1gb DDR333, 20gb Quantum Fireball hard drive, GeForce MX420 and a generic DVD burner. Sometime last year it quit booting into Windows consistently, would only cold boot (if you hit reset button or tried restarting from Windows or whatever, system wouldn't POST) and it had got very freaking noisy. Anyways by the time I got it back last week, it wouldn't boot into Windows but it would POST. I believe the problem might be related to more than half the capacitors being bulging or leaking.
Anyways, old hard drive is in my desk drawer in case any data on it is needed again. A 7200rpm WD drive is in there. With the CPU's bus underclocked to 100mhz and the cpu undervolted a little, it reboots fine and boots Windows everytime. I'm not sure what I'll do with the system but I'm going to see how long it lives from here with the current mobo, a DFI LanParty NFII. Fresh install of Windows 7 which has proven to be an interesting experience. It's usable, I'll stop my assessment there. Also, with the cpu underclocked and undervolted, I didn't feel so bad about flat out tossing the el cheapo fans that grew very loud from age. From here, I'm not sure what direction I'll go with the system but it's nice to have another machine to use as a toy again.
Reply 1 of 19, by Filosofia
Yeah! I remember the LAN Party series with the fluorescent pci slots and the handle to carry your case to the party. Too bad those bad caps from the new millenium 🙁 I still have my 1998 DFI P2XBL with zero bad caps, but anything after that can have that problem.
It would be a fine contender for Win98 gaming (1998-2002) but the mother board is the heart of the system and unless you can and like to substitute those caps yourself...
You can always try to find another mboard.
Athlon systems are cool 😎 :
My Windows 98 Dream Machine: El Cheapo Comeback.
ATHLON 64 DUAL BOOT WIN98SE/WINXP SYSTEM
BGWG as in Boogie Woogie.
Reply 2 of 19, by 3DfxNerd
if the caps are all about to blow, replace the board. if its a real nice board you like, then you can re-cap it. just make sure the uF rating is the same, voltage doesn't matter.
Insert creative signature here.
Reply 3 of 19, by Old Thrashbarg
Voltage does matter, the rating needs to be the same or higher than the originals. Also you'll need low ESR caps... it's not such a big deal on PII/PIII boards, but starting with the Athlon and P4 boards it's critical.
The LanParty NFII is definitely worth recapping, it's one of the better Socket A boards.
Reply 4 of 19, by luckybob
NOT true.
if you put a 6.3v cap in a place where it will see 12v. you might as well put firecrackers on your motherboard. if you do the opposite, its okay, but often the cap will be too big. more volts = bigger caps.
With the relative cheap prices of caps, get the right ones.
Reply 5 of 19, by GXL750
I might try to recap it one day. After all, capacitors aside, this is probably the nicest Socket A board I've seen. For now though, I'm kind of curious as to just how much longer the thing will run and just how much further I can push it.
Reply 6 of 19, by Old Thrashbarg
Running with bad caps can cause damage in the long term. It usually won't blow anything up immediately (unless one of the caps goes shorted, which does happen sometimes), but it does put considerably more stress on the VRM circuitry.
Reply 7 of 19, by 3DfxNerd
old thrashbarg is right, it can cause irreversable damage to the CPUs voltage circuitry, which is 1 thing you don't want unstable. if it gets too high, no more CPU. if too low, it will perform like crap/not at all.
@luckybob what I meant to say was as long as its same/higer it doesn't matter, my mistake for wording that wrong.
Reply 8 of 19, by nforce4max
There is two ways of doing it and the other I have not had any problems replacing caps with the same voltage but different UF. It all comes down to the circuit and what it will tolerate. I have seen people use caps that were twice the voltage of the ones that they replaced.
Reply 9 of 19, by Hatta
No, there's only one right way to do it. Replace caps with the same capacitance value and equal or greater voltage. The voltage rating is just the maximum voltage the cap can stand without blowing. Since the voltage applied to the cap is determined by the circuit, and won't change, you can use a higher rating.
The capacitance however is what caps are all about, and if you use a different rating the effects will depend entirely on what the cap is actually doing in the circuit. It may not matter, it may not work at all. If you don't understand the circuit enough to be certain that a different capacitance value is not going to matter, don't mess with it.
Reply 10 of 19, by ncmark
I don't think of Athlon XP as that old - my fastest computer is an athlon xp2400+ 😳
Reply 11 of 19, by Filosofia
🤣, yes I know what you mean, only a decade ago. It was a very interesting time in terms of tech evolution, so that is one point, and for the ones of us that have good memories associated with the beginning of the new millenium is good to relive it.
Reply 12 of 19, by GXL750
IMO, it the Athlon XP itself is a great chip but it feels like the majority of motherboards and many chipsets that support it are pieces of crap. Also, for daily use, while the Athlon XP might have had an edge back in it's day, it feels like NetBurst aged a little more gracefully.
I do remember back in 2002 building a brand new Athlon XP system. It's the first system I played any serious games on. I never realized the performance potential back then because the motherboard I used took PC133 SDRAM. It wasn't until years later I got a few motherboards that used DDR. That was also my first experience with a SiS chipset which I found to be very nice. It's too bad they never became very popular; they made a much nicer product than VIA.
Reply 13 of 19, by Filosofia
I think AMD itself had a chipset that was very decent, never got my hands on any motherboard though, but your right the Athlon was a good cpu, but that's no good if chipsets screw it up. That's why we have to thank nVidia for the nForce!
Reply 14 of 19, by 3DfxNerd
I still use a P4 today, they don't show their age if you upgrade them to 2GB of RAM and a 128MB vid card, it can still do more than my new laptop can. and the main computer I use was made in 2004, and re-built by me in 2008.
Reply 16 of 19, by jmrydholm
I play the Non-BFG edition of Doom 3 on my Barton core Athlon XP. I use an NVidia 5900 XT AGP card, still looks terrific. Ironically I have two 12MB Voodoo 2 cards in there, but I have yet to get that 3dfx Doom 3 patch working. I thought the screenshots looked kinda ugly texture-wise, but it was still a cool thing to try.
"Oh noes, my noez!!"
http://www.hwsetup.it/images/screenshots/3dfx … 15193533_35.jpg
"The height of strategy, is to attack your opponent’s strategy” -Sun Tzu
“Make your fighting stance, your everyday stance and make your everyday stance, your fighting stance.” - Musashi
SET BLASTER = A220 I5 D1 T3 P330 E620 OMG WTF BBQ
Reply 18 of 19, by GXL750
The reason consoles dominate is because they provide a dedicated platform with minimal overhead specially optimized for games whereas computers have to do a number of tasks. High end computers and even many mid range will always provide better graphics than contemporary consoles. However, between the fact most computers in use are low end systems designed for spreadsheets and internet, and the fact consoles provide a consistent platform from user to user without deviation in specs, it's safe to say it will still be a couple more years before computers are able to kill the console market.
On top of that, there's a certain edge to be had from minimal boot times and not having to install and activate every game you play. It's much easier to bring a playstation game to a friends house to have fun than it is with a PC game.
Reply 19 of 19, by Hatta
An edge that has been completely lost with the current generation of consoles.
