First post, by kataniel
I have a DX4/100 and I tested it with several graphics cards
It's a Dell Optiplex with 32 MB RAM and an onboard Cirrus Logic 5429 with 1 MB. In addition, I tested two VLB cards in this machine,
In 3DBench2 the results are:
- Cirrus Logic GD5429 1MB - 58.3 fps
- Tseng ET4000W32P VLB 2MB - 60.6 fps
- S3 Trio32 VLB 2MB - 59.8 fps
I thought, the Trio32 should perform way better with this config, as it is the most modern one. Is the CPU the limiting factor here?
Thanks in advance.
Dell Optiplex GL5100 | Pentium 100 | S3 Trio64V+ 2MB onboard | 64MB EDO | WDAC2850 | FX810 | OPTi 82C929 + NEC XR385
Dell Optiplex 466LE | am486 DX5 133 | CL-GD5429 1MB onboard | 8MB FPM | WDAC2540 | FX400 | HOT-235 + DB50XG
