First post, by simbin
- Member
For a long time I've been buying SLI capable mobos, running single card setups. I always think, "One day I'll upgrade" and then I build a new PC.
So I finally found a cheap card that matches my old one, an 8800GTS 320MB. Before this card was taken out of commission, it was running World of Warcraft with ALL MAX settings, except shadows at 1920x1080.
Anyhow, I got a good price on a slightly damaged card, untested, being sold as-is. My fingers are crossed!
From what I can tell in the pictures, just the corner of the board is damaged. There doesn't appear to be any traces or anything in that spot, so hopefully it will all still work.
Other Specs:
Abit KN8 SLI nForce4 Motherboard
2GHz Athlon X2 Manchester Socket 939 Dual-Core
2x1GB (2GB) PC3200 DDR (not sure if ECC will work)
YAY! I just found this in my mobo manual:
Supports Dual channel DDR 400 ECC/non-ECC un-buffered memory
Thermaltake Matrix VX VD3000BWA ATX Mid Tower
http://www.newegg.com/Product/Product.aspx?It … N82E16811133008
WIP: 486DX2/66, 16MB FastPage RAM, TsengLabs ET4000 VLB
Check out my Retro-Ghetto build (2016 Update) 😀
Commodore 128D, iBook G3 "Clamshell"
3DO M2, Genesis, Saturn, Dreamcast, NES, SNES, N64, GBC
