MS DOS 6.22 Language
First post, by Stojke
How the heck do i change this crazy thing back to English?
Its currently on German.
I edited the part where it says 049,850 to 001,437 but its still on German.
Reply 2 of 9, by Filosofia
where did you changed it? the autoexec? the config.sys? Keyboard ? the codepage itself?
Reply 3 of 9, by Stojke
config.sys
Don't you need an English version of DOS 6.22?
I think so too.
Reply 4 of 9, by Davros
try this
Autoexec.bat
country=049,850
Device=c:\windows\command\display.sys con=(,,2)
Config.sys
mode con cp prepare=((858 850) c:\windows\command\ega2.cpi)
mode con cp select=858
keyb is,,c:\windows\command\keybrd2.sys
the code for Germany is
049 = country code
850, 437 = The code page
edit as nessesary my memory isnt too good think of the above as a starting point
Reply 5 of 9, by Filosofia
you don't need an "english version" of dos 6.22
just post your config and your autoexec, it's easier that way 😀
Reply 6 of 9, by Stojke
Ive already reinstalled.
But thanks any way 😁
Can you tell me what would you have changed in the exec and config so i know?
Reply 7 of 9, by Davros
I totally misread the first post and thought you wanted english to german sorry about that
try
Autoexec.bat
mode con codepage prepare=((850)e:\dos\ega.cpi)
chcp 850
mode con codepage select=850
keyb us,850,e:\dos\keyboard.sys
Config.sys
device=c:\dos\display.sys con=(ega,437,2)
country=001,437,c:\dos\country.sys
Reply 8 of 9, by Stojke
Thanks, i will try both until i get it to German and back 😀
Reply 9 of 9, by Filosofia
Oh I was just going to compare with my files to see where the error could be (I have installed english)
If you need to alternate between languages you should take a look at country.txt 😉
