First post, by jpb1991
I need help activating Operation Body Count CD Cheats in Dosbox. I type in MOUNT E E:\ -t cdrom . I then type in BCCD.exe NSR250. I have to put a space because I get an error when I type it without a space. I try to enable the CD cheats according to the information at http://www.gamefaqs.com/pc/564974-operation-b … dy-count/cheats . It does not work. I get an activation message, but it will not let me warp or go to god mode. How are the cheats suppose to be entered? When I type in BCCD NSR250 it tells me that I need a CD when the CD is already in the drive. I figured it out. I needed to press Alt then the corresponding cheat letter.
Reply 1 of 3, by bloodbat
Err you either didn't read it thoroughly or you forgot to mention the shift:
"In the Body Count DIR, type BCCDNSR250. Start a level and press Left Shift + Alt + B to enable the following cheats:
Effect Code
Invincibility Toggle Left Shift + I
[and so on]"
The space is probably needed since it looks like a parameter and you get an activation message.
Reply 2 of 3, by jpb1991
The Operation Body Count CD that I am using is not the original CD. God mode is Alt + I for my version. I do not know why that is.
Reply 3 of 3, by bloodbat
It is weird...unless you messed with the keymapper.
Anyway...cheats work now?
Make sure you're mounting the CD whether you type BCCD or BCCD.exe.
