First post, by mr_bigmouth_502
It looks great and it works quite well (aside from the menu screens being in the wrong aspect ratio, but that's not that big of a problem 🤣), but I would like to know what kind of Glide emulation they used, and how I can tweak it for better speed and stuff. 🤣
Normally I'd be able to figure this out myself, but just from looking through the files it's a whole mess of config files and folders-within-folders, and it's just laid out in a really screwed up way. 😜
Reply 1 of 12, by leileilol
Considering the iphone port, I'm surprised they didn't take it all into native OpenGL by now.
Reply 2 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
They used a modified build of dosbox and nglide. You can configure it by copying/installing nglide yourself as GOG.com for some reason has removed the nglide configuration utility
Water flows down the stream
Reply 3 of 12, by VileR
Yes, that's what I had to do... really not sure what they were thinking with this release. I want to waste those cops at native resolution!
Reply 4 of 12, by mr_bigmouth_502
Thanks! 😁 I'll give that a try.
EDIT: It works great, and now that I'm running it at native resolution it looks smoother too. 😀 Now what I'm wondering is, how can I set it so that the 2D screens (menus, map, etc.) are displayed in 4:3 and not in a small 16:10 box?
Reply 5 of 12, by Gamecollector
.conf editing, of course.
aspect=true
fullresolution=desktop
output=ddraw (overlay and surface aren't scaling)
scaler=none.
Reply 6 of 12, by mr_bigmouth_502
Gamecollector wrote:
.conf editing, of course. aspect=true fullresolution=desktop output=ddraw (overlay and surface aren't scaling) scaler=none. […]
aspect=true
scaler=none.
Tried that, it doesn't do a thing. 😜 The 2D screens being in the wrong aspect ratio aren't *that* big of a deal, but it is something I would like to fix.
Reply 7 of 12, by Gamecollector
Err... I'm 100% sure GOG is using the separate .conf, not the default.
Reply 8 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
Probably has no influence on the screens rendered by the glide wrapper.
Reply 9 of 12, by btw3d
Which version are you running? If it's 3dfx mode, you need to set 4:3 aspect ratio in nGlide configurator (it's removed in this release, so you need to install nGlide 0.99 and open configurator from the start menu).
Reply 10 of 12, by mr_bigmouth_502
Already did all that. 😜 The ingame screens are already in 4:3, so they're fine, but the map, menu screens, and FMVs are all in a slightly stretched 16:10 window in the center of my screen.
Reply 11 of 12, by btw3d
Then you're completely fine.
Those small black bars in the menu/map are a feature of 3dfx version.
Reply 12 of 12, by mr_bigmouth_502
Oh, ok. 🤣
