First post, by Glitchologteam
hello, I have a program called ''Clipmaster'' and im ALSO AWARE THAT DOSBOX IS FOR GAMES AND NOT NECESSARY APPS, but still, if anyone can help it would be appreciated. When I try to install the game by using ''Install.bat'' I get the following message
Sorry, you must specify a drive on the command line to configure Key Clipmaster correctly. For instance, the following command: INSTALL C:, will copy the files to a directory called /KCM on drive C:. And configure Key Clipmaster to run from the directory.
even if I do ''INSTALL C:'' , nothing happen at all...
I use the default option of dosbox 74
mounted c c:\LEGR so I could install the program in
This programs comes with 2 Floppy and was made in 1990
If any details are missing, let me know and ill add them
Reply 1 of 1, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Look at the INSTALL.BAT for an idea of what it's doing and where it might be having a problem. As an example, it could be trying to use XCOPY, which will fail and do nothing unless you make that program available through the path.
