First post, by vetz
- l33t
Have installed my new Midiman MM-401 card and it works nicely. I have two questions regarding it:
1. After playing/testing Space Quest III I loaded up Monkey Island. The sounds from the MT-100 was completely wrong most of the time. After some trial and error I just turned the MT-100 off and then back on again which fixed the problem. Any explanation for this?
2. A newer DOS game, Battle Arena Toshinden does not detect the MM-401 in the soundsetup, but works fine with the MIDI connector on the soundcard. This happens even if the MM-401 is the only midi device setup in the system.
