Warcraft 2 on Mac OS X.5
First post, by howarthe
I'm trying to run Warcraft 2 on a PowerBook G4 running Mac OS X.5. I found and downloaded DOSBox 0.74, and followed the instructions on the Wiki:
I inserted my CD.
I created a folder in /Users/erin/Warcraft2
I launched DOS BOX and entered the following command lines
1) mount C ~/Warcraft2
RESPONSE: Drive C is mounted as local directory /Users/erin/Warcraft2
2) mount E "/Volumes/War2BNE CD" -t cdrom switch
RESPONSE: MSCDEX: Mounted subdirectory: limited support.
RESPONSE: Drive E is mounted as CDRom /Volumes/War2BNE CD/
3) E:
RESPONSE: E:\>
4) install.exe
RESPONSE: Illegal command: install.exe
I also tried "install" and "setup", but nothing worked so far. What should I do next?
Reply 1 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
dir *.exe
dir *.bat
dir *.com
Water flows down the stream
Reply 2 of 12, by howarthe
file not found 🙁
Reply 3 of 12, by IIGS_User
No file available which could be executed with DOSBox.
Are you sure it's Warcraft 2 for DOS?
Klimawandel.
Reply 4 of 12, by howarthe
The label reads:
WarCraft II: Battle.net Edition
Windows 98/95/NT 4.0
Power Macintosh
CD-Rom
Version 2.0
Reply 6 of 12, by bloodbat
Nor should it be mentioned: the Battle.net edition DOESN'T support DOS.
Reply 7 of 12, by howarthe
So, does anyone here know of any other way I might be able to play this game again?
Reply 9 of 12, by mr_bigmouth_502
Will those even work on a G4 processor?
Reply 11 of 12, by IIGS_User
What Mac OS requirements are given fot this particular game?
If pre-OS X (Mac OS 9 or earlier) , try to run the game within SheepShaver.
Klimawandel.
Reply 12 of 12, by Glitchologteam
at least for me, Warcraft 2 do not work very well on basillik II (if you ever thought trying that emulator). The music cut up and sometime the game will come to a halt that will crash the entire emulator. SheepShaver could be an alternative idea, but its HELL to install it (windows 95 on dosbox is easier)
