US Navy Fighters Gold
First post, by Sacrafire
Hi there, I'm pretty new to this idea of DOS emulation and all cos I just found my old Navy Fighters disc and decided to try it out again (I am running Windows 7 32-bit now).
Managed to get the game to install into my C drive normally like how it would on an old computer. After that, it would not run from the application, despite having set it to run at windows 95 compatibility, 256 colors and all. A black command prompt box appears for a second before it disappears, then nothing happens.
Using DOSBox, I followed the instructions given here: http://www.dosbox.com/wiki/Basic_Setup_and_In … ation_of_DosBox
I can select the USNF.exe application and make it "run", and I see several lines appear including the title and manufacturer of the game, but it tells me that it cannot detect the US Navy Fighters CD and I need to make sure a MSCDEX driver is installed.
Please help!! Thank you!
