Extract game music files.
First post, by marooned_on_mars
Not really a problem in itself but wasn't sure where else to ask. Is there any way to extract resource files from Sierra games? I've tried using SCI Viewer and it worked flawlessly, but I could only extract files one at a time and that can be quite tedious. I also tried SCIResDump but it doesn't seem to open any resource files I'm pointing it at. Thanks in advance ^^
Reply 2 of 40, by marooned_on_mars
Thanks for the reply!
Seems it extracted a lot of files of various extensions. I tried extracting the music with music.exe but I'm not sure which file I should open exactly. Opening resource.000 from LSL6 doesn't work apparently. I would want to extract the music and be able to render it outside the game (on various sound settings, or patches in this case)
Reply 3 of 40, by collector
Resource.exe will dump all raw SCI formats. There may be some small utility that can convert from SND to mid, but I am unaware of any. If there were a command line tool to do so for SCI1 and later, you it would be easy to write a bat file to batch process all of the SND files. As it is, all that I can suggest is to use the GUI version of the Sierra Resource viewer to go through one by one to export to MIDI.
If it were an SCI0 game, I wrote a companion utility for Soundbox to deal with audio resources for developers creating SCI games that can batch process SCI0's SOUND.* resources to MIDI, but it would not work with LSL6 resources.
Reply 4 of 40, by marooned_on_mars
Well, when I tried to extract file by file, first I tried to get GeneralMidi files and play them back in a normal player, but they'd turn out wrong. For example, in the Resource viewer, a song was more than 1 minute long, when I extract it out it turns out into a midi containing just one instrument note.
Reply 5 of 40, by collector
There are not specific kinds of MIDI files. Each SOUND resource contains tracks for the different kinds of audio hardware on which the game might be played. The resources also contain PATCH files for each of the different kinds of hardware, even for PC speaker. All of this is why the Quest Studios actually records its MIDI files during game play instead of extracting them.
Reply 6 of 40, by marooned_on_mars
So I take it there's absolutely no way of properly diverge the tracks/patches? I would've been interested only to extract the game's GeneralMidi tracks, since recording that in DosBox can be quite an hassle when using an external midi device (software).
Reply 7 of 40, by NewRisingSun
Sure there is. SND2MID.COM is a command-line utility to convert Sierra Music Files (used by SCI, among other Sierra products) to standard MIDI files. Syntax is
snd2mid devices files
Devices is a sequence of letters denoting which devices' tracks you want. "a" is adlib, "m" is Roland MT-32, "h" is General MIDI, "*" is all. For example:
snd2mid hm 1.snd
extracts General MIDI and Roland MT-32 tracks from 1.snd to 1.mid.
snd2mid * *.snd
extracts all tracks from all *.snd resources into *.mid.
If you want to convert Standard MIDI Files to Sierra Music Files, for example to change a game's soundtrack, there's a SCI0 utility coming with SCI studio (I think), and for SCI1, Sierra's original utility (SMF.EXE) is to be found somewhere on the internet.
Reply 8 of 40, by collector
SND2MID is Ravi Iyengar's utility for SCI0. My utility has an updated (Win32) version of SND2MID for batch processing. However, marooned_on_mars wants to extract from LSL6. Ravi never intended that it could be used fro any other version of SCI. Neither SCI Studio nor SCI Companion have any audio capabilities. Ravi Iyengar did create Soundbox to create and edit SCI0 SOUND resources, but it has to be used as a standalone utility. Soundbox can be invoked from Studio, but not Companion.
Reply 9 of 40, by NewRisingSun
This one isn't. (Maybe it should be called something else to avoid confusion.)
Reply 11 of 40, by NewRisingSun
Of course the source exists --- I'm not dead yet... 😀
Reply 13 of 40, by NewRisingSun
I wrote it in the 1990s, so it's an x86 assembly language program... not very portable. I once started rewriting it in portable C, but considered it a waste of time, since the original runs well enough in DOS emulators.
Reply 14 of 40, by marooned_on_mars
Thanks NewRisingSun, I tried your utility and it seems to be getting GM-pertinent midi files, but seemingly it doesn't sound right when I play them. I'll attach a comparison. Also it doesn't seem to loop properly, as it usually starts from the 2nd part of a song's loop. Sorry for the skips and crackles in the DosBox version of the recording, that's the reason why I never record externally from DosBox.
Oh and also forgot to mention that the SierraViewer seems to be playing the GM versions of the songs the same bad way.
Reply 15 of 40, by NewRisingSun
That's right --- loop points must be interpreted by the MIDI player. Since SCI uses a very idiosyncratic way of defining loop points (using program change value 127 on channel 16, if I remember correctly), you'll have to either write your own MIDI player to interpret it that way, or edit the Standard MIDI File using a MIDI sequencer program. That's the price you pay when using extracted, as opposed to recorded, MIDI files. (Be glad you're not extracting LucasArts' iMuse files.)
The pitch bends don't sound right because GENMIDI.DRV sends the pitch bend range to 12 (default was 2) upon program start, using information in 4.PAT. So, to get it to sound right, send the following sequence (all hex values) to every channel before playing back the extracted MIDI files:
Bx 65 00
Bx 64 00
Bx 06 0C
With x standing for the MIDI channel number 0 to F.
And of course the beach sound effects come from a different MIDI file, which the game plays simultaneously with the music.
Reply 16 of 40, by marooned_on_mars
Any suggestions of a MIDI sequencer? And what is the trouble with iMuse when extracting? Would like to know.
Would this problem with the pitch bends be present when recording raw midi commands through DosBox?
NewRisingSun wrote:
The pitch bends don't sound right because GENMIDI.DRV sends the pitch bend range to 12 (default was 2) upon program start, using […]
Bx 65 00
Bx 64 00
Bx 06 0C
I don't really have a clue how to send that sequence or what to hex edit.
I was already aware of that =3
Reply 18 of 40, by marooned_on_mars
The reason why I want to do this on my own is for the fact that Quest Studios don't have complete soundtracks and I would require that. Also helps in case I didn't catch all the music from the game through playing/recording it. If this wasn't the case I would've chosen the easy path already.
Also, Quest Studios tampered with the music in some cases and it doesn't sound like in the game, and I want to make accurate recordings that sound exactly how they were supposed to.
Reply 19 of 40, by leileilol
indeed, queststudios has annoying long delays before each song and there is seemingly instrumental changes
I know how you feel and such. Space Quest V's intro song for example which never is played in full normally.
