First post, by mistermsk
mistermsk
Offline
Hi All,
I have got DosBox working with the config and used [autoexec] to mount and launch a program.
The problem I am having is, even in screen. when I loose my connection, DosBox ends. Since I never need to touch it, or look at what I am running, is there a way to fake DosBox to go to NULL versus the display? I have it running on a server and I have it through SSH. I can bring DosBox up and everything works fine in screen. However, if I close my connection with the server it ends.
Thank You...
