First post, by Tuz
Hi,
I cant get dosbox to compile on mac os 10.3 . when I do ./configure I keep getting the following error:
*** The sdl-config script installed by SDL could not be found
*** If SDL was installed in PREFIX, make sure PREFIX/bin is in
*** your path, or set the SDL_CONFIG environment variable to the
*** full path to sdl-config.
I have sdl 1.2.6 installed.
sorry if this has already been addressed but I have not seen any posts on this. Thanks.
