First post, by leojorcris
Hello.
I´m trying to run an old .exe file that uses GCA, it worked with Windows Xp, but with win 7 doesnt work, because of W7 doesnt work with full screen mode (driver problems) SO I´ve installed DOS BOX and ran OK, excep this FATAL issue: the aplication has a Clock to save data based in 24 hr format.
The aplication clock fails when the day ends ans start a new one,by putting 24:00:01..24:00:03... 25:00:32.. and so ...
The aplications should change to 00:00:01.. 00:00:03.. 01:00:32.
This issue dont´t happens in win xp.
Please can you help me with this? I´ve tried a lot of combinations, but no one is related to this problem.
Regards,
Jorge
