First post, by s3freak
I have spent quite a while searching for a solution to this as occasionally I like to leave DOSBox running in the background but without having its audio muted.
After searching for a while, the answer is to remove or comment out the mainwin = hwnd line under the DX5_SoundFocus function of src\audio\windx5\SDL_dx5audio.c and then recompile SDL.dll.
I include a patch if anyone is interested for their convenience. This patch should also work with other SDL based apps, not just DOSBox.
My 486 is my real DOSBox, as well as my customised DOSBox!
I am not very active on VOGONS, please send a private message if you need a quicker response!
Reply 1 of 2, by gulikoza
Perhaps a better solution would be to change
format.dwFlags |= DSBCAPS_GLOBALFOCUS;
to use global focus in the first place.
Actually I don't know why SDL uses STICKYFOCUS by default.
http://www.si-gamer.net/gulikoza
Reply 2 of 2, by s3freak
Thanks for the info. At the moment, I am not enhancing my builds further, but if I get time to do so, then I will consider this method.
