First post, by Keith
Hello,
I'm working on getting DOS6.22 and WfW3.11 online in the DOSBox MegaBuild6. So far, I was able to get the NE2000 driver working in Windows. However, after trying to get the TCP/IP Protocol to work, I ran into some issues. Trying to start Windows showed the logo, then the screen just went black, with a command prompt cursor. One solution I read online was to place DEVICE=C:\DOS\EMM386.EXE in CONFIG.SYS. Tried it, and it didn't work. So, I took it back out.
I figured that I'd try a ping command, and see what happened. So, I tried a ping to my router (192.168.1.1). I got an error about contacting the IP Driver (Error Code 0). In Windows, I set up the settings for DHCP, in DNS, I set 192.168.1.1, and in Advanced, I checked off both of the Windows Networking Parameters.
In the DOSBox config file, I have it set as follows:
ne2000=true
nicbase=300
nicirq=3
macaddr=AC:DE:48:88:99:AA
realnic=Atheros
With list, my wireless card did not show up in the Status Window. I tried using a Loopback adapter, but that did not work either. So, I just manually typed in Atheros, and it appears that that did not work either.
Anyone have any ideas on how to get this working? I'd prefer to stick with DOSBox... it's a great emulator.
Thanks![/code]
Reply 1 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
For Windows networking to work you need to boot an image inside DOSBox.
1+1=10
Reply 2 of 13, by Keith
Which is what I'm doing. Should've mentioned that, sorry.
Reply 3 of 13, by Jorpho
MB6 is in theory kind of old at this point and offers no particular advantages over ykhwong's build.
Don't you need winpcap?
Reply 4 of 13, by Keith
Have it installed. I actually tried installing it twice, since it wasn't picking up my adapter. (plus it needed to be updated. 🤣)
Reply 6 of 13, by Keith
Status Window says that it's using the MS Tunnel Interface Driver on localhost. I read somewhere else to try that driver, but it didn't work. I have that set, only because it chooses to not recognize my real card, an Atheros 802.11 a/b/g/n Dualband Wireless Network Module. I'm thinking that the issue is with WinPCap communicating with DOSBox. If that's the case, how would I get it working correctly? If it's not, is there any other potential problems there could be?
Edit: Just saw your question about the list parameter. This is what I get:
- Network adapter 'Realtek RTL8168C/8111C PCI-E Gigabit Ethernet NIC' on local host
- Network adapter 'MS Tunnel Interface Driver' on local host
- Network adapter 'Microsoft' on local host
- Network adapter 'Sun' on local host
- Network adapter 'MS LoopBack Driver' on local host
Reply 7 of 13, by Jorpho
A moment's Googling does indeed suggest that Winpcap and wifi drivers do not mix.
http://www.winpcap.org/pipermail/winpcap-user … ber/004490.html
Perhaps the Network Monitor suggested therein is worth a try.
What other values for realnic have you tried? "Atheros" evidently isn't going to do it, since it isn't even in the list.
Reply 8 of 13, by lucky7456969
You should list out your realnic first, then write it down.
And re-open the dosbox.conf and write that number into that file.
It's a matter of detection.
Reply 9 of 13, by Keith
Jorpho wrote:
A moment's Googling does indeed suggest that Winpcap and wifi drivers do not mix. http://www.winpcap.org/pipermail/winpcap-user […]
Wouldn't work. All network monitor does is just capture packets for reading. It can't act as a driver. Capturing isn't the same as sending/receiving.
I've tried using LoopBack as well, with the same results. Does Error Code 0 definitely mean that the problem is outside of DOSBox, and that there's no way that it can be anything inside of MS-DOS?
And I remembered reading something about WinPCap and wifi cards... but I thought that they would've fixed it. So, it looks like my only option would be to use LoopBack, but I have no idea why that wouldn't be working, either.
Before I fool around with things on my PC outside of DOSBox, I just want to be sure that there's nothing else that could be the issue inside of DOSBox itself. Am I setting the proper settings inside WfW for a DHCP setup (see original post)?
Reply 10 of 13, by Jorpho
Hmm, I misread that earlier.
Meaning, you used "realnic=loopback" in your DOSBox.conf? Did anything appear in the status window?
I'd say the lack of anything in the status window is more telling than anything else.
If you want to rule out problems with Windows 3.x, you can try using the Novell IPX drivers at http://home.arcor.de/h-a-l-9000/ne2kstuff/db_ne2000.html in DOS for testing purposes.
Reply 11 of 13, by Keith
Sorry for the late reply, I was busy with quite a few things.
Anyways...
I meant I used the list number for the loopback adapter. Trying to type in "MS LoopBack" displays normal output/expected output in the status window, but returns the same results when trying to use it. I'll take a look at the IPX Drivers.
Thanks.
Reply 12 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Maybe disable COM2 as it uses IRQ3. If it still says something about IP driver error the error could be in your Win3.11 configuration.
1+1=10
Reply 13 of 13, by Keith
You meant in the config file, right?
serial1=dummy
serial2=disabled
serial3=disabled
serial4=disabled
Still got the same results. 😖 It did get rid of the warning that came up when trying to configure the network adapter, though.
