Turbo display LED
First post, by Robin4
Does anybody know how this display LED is calling?
I need to know the type.. I know there are different ones to get..
But i dont know the type of that imaged one.
Reply 1 of 4, by badmojo
The white plugs on that one look case specific to me, all of mine simple have jumper blocks to take the power, turbo switch, etc.
Reply 2 of 4, by Robin4
I mean that LED display only.. ( i need that part to solder it in)
I need the part number and or type..
Reply 3 of 4, by Robin4
No body know the type of the LED display?
Reply 4 of 4, by Machine_1760
It's a matrix of seven segment displays.
http://en.wikipedia.org/wiki/Seven-segment_display
You should be able to buy them quite cheaply from component sales websites such as RS Components.
You may find you need to buy 3 and connect each individually. I've not seen one like yours though. It may be that you can leave a couple of segments unconnected.
Here are some examples from RS:
http://uk.rs-online.com/web/c/displays-optoel … &view-type=List
