First post, by Mau1wurf1977
- l33t++
I have spent all day figuring out how to burn a CD-ROM from the GOG.com version of Pinball Illusions (It comes with CUE/BIN files + 50 or so OGG files for CD Audio).
20+ non working CD-Rs later I believe I have figured it out.
However I ran into a roadblock when trying to run it on the PC. The game installs just fine (by running INSTALL.EXE from the CD).
You start the game with ILLUSION.BAT and on the PC I get this error screen:
However...
When I mount the CD in DOSBox, the game runs perfectly. All the Music is through CD-Audio and tracks change correctly.
Also when I disable HIMEM.SYS AND EMM386.EXE in CONFIG.SYS the game does run on my PC:
So I'm wondering what could be causing this. I have tried only disabling EMM386.EXE and I get the same error.
I am running MS-DOS 7.1. The machine has a Pentium MMX 133 and 64MB of RAM.
AUTOEXEC:
SET SOUND=C:\SB16
SET BLASTER=A220 I7 D1 H5 P300 E620 T6
SET CTCM=C:\CTCM
C:\SB16\AWEUTIL /S
C:\SB16\MIXERSET /P /Q
SET PATH=C:\DOS
LH C:\DOS\DOSKEY.COM
LH C:\DOS\MSCDEX.EXE /V /D:CDROM001 /L:D
LH C:\DRIVERS\LOGI730\CLOAKING.EXE
LH C:\DRIVERS\LOGI730\MOUSE.EXE
CONFIG
DEVICE=C:\CTCM\CTCM.EXE
LASTDRIVE=Z
DEVICE=C:\DOS\HIMEM.SYS /TESTMEM:OFF
REM DEVICE=C:\DOS\EMM386.EXE RAM
DOS=HIGH,UMB
DEVICE=C:\DRIVERS\CDROM\CDROMDRV.SYS /D:CDROM001
FILES=40
