Worms problem
First post, by iSteve
Greetings,
I have trouble running worms - I manage to run it, but the video output is unsuable
screenshot : http://isteve.rulez.cz/pics/worms_trouble.png - also, the screen is -blinking-
Tryed on v0.60 (from debian/sid repostiory) and CVS from 9.12.2003
Any ideas how to make it work ?
Reply 1 of 6, by iSteve
oh, forgot -
Mobo: MSI KT4 Ultra, chipset VIA KT400
CPU : AMD Athlon XP 2000+ (x86, i686)
RAM: 512MB DDR, 333MHz
Graphic: Prolink GeForce 4 Ti4200, 64MB RAM
Sound: Some C-Media onboard
OS: Debian GNU/Linux
Game name: in title, it's Worms 😀
Description in post above.
Reproducibility: For me, always, whenever I run worms 😀
Sound mode ... umm ... default I guess ? ... otherwise, using ALSA from 2.6-test10 kernel
Video mode ... umm .. didn't set anything in dosbox conf either, so have no clue - using closed-source nvidia drivers
Version of emulator: as above, 0.60
Steps I did already: Nothing much, don't have a clue where to start
Reply 2 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
I don't get passed the dos4gw screen.
edit: I forgot to mount the data directory as CDROM 😀
Okay the game is fine with 0.60-3(unstable as I maintain the package so installed it as well ) So didn't try with 0.60-2
I have NVIDIA drivers -closed source
2.4.23 kernel
futher everything from testing
Does the behaviour improve if you switch to fullscreen ?
Water flows down the stream
Reply 3 of 6, by iSteve
Nope - altho I don't do fullscreen like in the way of resizing - am I supposed to ?
(I'm not quite a fan of it, my x is configured a bit weirdly in order to get the best res/refresh ratio)
Reply 4 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
Well there are 2 possibilites:
1. your copy of worms is weird (unlikely)
2. libsdl and X aren't talking the same language.
why these 2. If a game works in dosbox then your hardware is not relevant.
dosbox emulates everything.
dosbox inturn outputs its own graphics to SDL which does it to X
So either SDL/X is broken
Or the game.
but if you have a copy of the game that works on a other pc with dosbox it works on your pc as well.
Reply 5 of 6, by iSteve
broken game is possible ... but then, I'll be sad :\
Anything else sdl-like and x-like works fine for me - and dosbox things, too (A lot of other old games, like xenon2, golden axe etc.😀 ...
Reply 6 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
well maybe you can find it somewhere. I found it to test it so it isn't that hard.
