Put the CD in the drive?
First post, by DiggityDanks
I am trying to play Full Throttle but when I try to run it, it says that the CD is not in the drive even though it is.
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
did you mount your cdrom drive ?
as cdrom ?
futher you can specify the the volume label of the cdrom seems to help as well.
Look in the readme on how to do it.
Water flows down the stream
