First post, by Neville
I'm having issues with these two:
Alien Alley --> Works fine, but I couldn't set up sound. The gamer offers SB and GUS support via two different BAT files, but after executing them the game just won't play sound.
Pro Wrestling Promoter --> This one comes with an install program, GO-PWP.COM, using UNARC. Problem is, it fails to install to the right folder, and extracting files directly is not an option, because the game seems to use subfolders and the ZIP file doesn't have any path names.
Reply 1 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Alien Alley - The game uses the DIGPAK drivers, but only includes generic ones. Get the full driver package named DMKIT150.ZIP (such as from here) and unarchive it into the game directory. Then run SETM to choose a music driver and SETD to choose a sfx driver.
Pro Wrestling Promoter - It's got a simple ZIP file, so just extract all the files into C:\PWP and then create a subfolder named DAT and move *.DAT in there.
Reply 2 of 2, by Neville
Right in both cases. Thank you!
