First post, by rfnagel
- Oldbie
I'm not sure if I'm doing anything wrong here, but I can't seem to remap any of the buttons on my Gravis gampad to keyboard key presses.
I can start the DOSBox key mapper (via CTRL+F1), remap the buttons there, and then save the custom mapping (and yes, the "Mapper.txt" file is indeed being saved with the custom mappings). But, when at a DOSBox prompt the custom keys are not typed/entered into the prompt when pressing the corresponding joystick (gamepad) buttons.
Now, when the mapping is set to the defaults (e.g. "button 1 = button 1", "button 2 = button 2", etc...), that seems to work just fine.
Attached is a screenshot collage of what I'm refering to (and to prove that my gamepad is indeed functioning):
Screens 1 - 4 = Default key mapping for the joystick buttons.
Screens 5 - 9 - Just to show that my gamepads are indeed working with the default mapping (an old crude QBasic utility of mine running in DOSBox, works well shelled out of Windows XP as well).
Screens 10 - 13 = This does NOT work 🙁
Is this a bug in the current version of DOSBox, or am I simply doing something wrong (probably the latter of the two 🤣!)?
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
