bjt wrote:I've copied the installer and the rest of the files from the game folder, and burned a CD from the GAME.GOG iso file. The game starts up fine under DOS, but some (not all) of the digital sound effects and speech are corrupted (static). Has anyone else tried the GOG version under DOS?
Hi there!
Thanks for checking our my Videos 😀
I also ran into this issue...
The issue when the machine has more than 16MB (Megabyte) of EMS memory.
You have two options:
a) Put only 16MB of memory in your machine
b) Tell EMM386.EXE to only use 16MB
You do this in the CONFIG.SYS through
device=c:\dos\emm386.exe 16384
And lastly make sure you configure the correct IRQ and DMA in the SETUP.EXE (or whatever it is called for this game).
