3dfx DOS modes
First post, by kithylin
There's a couple threads on this probably but some are difficult to read and I've been trying to understand this myself for a long time.
I have a retail copy of Descent2 (Original disc), and Carmageddon SPLAT Pack (also Original disc).
What I'm trying to find out is they have a "3dfx" alternative mode, and if I remember correctly, this was possible to run inside dos -WITHOUT- using Win9x.
The problem is this was many years ago and I didn't step in to the 3D field until the voodoo2 era and Win9x and Direct3D games.
So my question: If I want to use this 3D mode in DOS, with 3DFX mode, Can someone tell me -exactly- which video card I need to do this?
Also, are there any special software / TSR's / Drivers necessary to run via autoexec.bat / config.sys for these cards to work, -BEFORE- loading the game's 3DFX EXE?
Or if I can locate one of the cards, can I just stick the card in and go run the EXE and it instantly works?
I would guess and assume an original voodoo1 may work, those are a little hard to find these days though. Would a voodoo2 work? Those are easier to find, but not always cheap today. If a voodoo3 would work, I'd just use that over anything else, they're found cheapish and commonly today.
I just want to see this mode work under dos. I've never, ever, ever seen it running anywhere and supposedly it was possible. I also have the original Quake-1 CD-ROM Disc and I believe it supported a 3dfx mode under DOS too.
Reply 1 of 35, by Mau1wurf1977
Well back in the day I had a 3DFX Voodoo and on various PC magazines you would find patches for games. These patches would add 3DFX support. Games like Tomb Raider, MDK come to mind.
Several people tell me that the Voodoo 2 is just as compatible, but needs some environment variables set. I will play around with this in the near future, but confident it will work. Later cards are not that good for DOS support I believe.
My YouTube channel
Reply 2 of 35, by vetz
DOS Game list: DOS Glide Games List
If the game require a patch, check out www.patches-scrolls.de
Voodoo 2 will work with the DOS Glide games, but may require a batch file to be loaded with environment variables. Other than that the game should load the 3DFX card with no other input.
Voodoo 2 on Glide games (includes environment variables): http://www.3dgw.com/faq/moodys_voodoo2_faq.htm
Reply 3 of 35, by Davros
no, opengl under windows
Reply 4 of 35, by kithylin
Thanks guys for all the information, this is a big help.
So other than the environment variables for some games, I just install the voodoo2 (with the VGA cable) and then load the game's patched 3dfx file (in real mode MS-DOS) and then the games go and there's generally nothing else to do?
Reply 5 of 35, by gulikoza
No, generally there's nothing else to do. What you might wanna keep in mind is that DOS Voodoo driver is actually the glide2x.ovl file. Some games install this file along with the game and the version installed might be an older one supporting voodoo1 only for example. In this case you can safely replace it with a newer one.
http://www.si-gamer.net/gulikoza
Reply 6 of 35, by kithylin
I found this: http://www.youtube.com/watch?v=pYXF_VhAhlI
Indeed, Quake I did to 3D Accelerated modes under MS-DOS (-NO WINDOWS-) However, It looks like it's restricted to some "rendition verte" cards, not voodoo. 🙁 Oh well.
Reply 7 of 35, by leileilol
and that's only on certain rereleases it would come with it on the CD. The original releases from 1996 only did DOS quake ver 1.01 and 1.06
long live PCem
Debian's fucked
Reply 8 of 35, by akula65
With regard to Descent II, use the Wayback Machine (http://www.archive.org) to view Dorsola's/KieferSkunk's Descent II 3dfx FAQ
http://www.kieferskunk.net/d2_3dfx_m.htm
This page has links to the Descent Network which, unfortunately, no longer work. You can download the latest versions of the 3dfx patches for Descent II here:
http://www.dfiles.de/download/d2/patches/d2_3dfx106b.exe (Unofficial Andy Hanson update)
http://www.dfiles.de/download/d2/patches/d2voodoo.zip
Use the second file only if you have less than 32 MB of memory. The second file also requires that you be running Version 1.1 or 1.2.
Reply 9 of 35, by bjt
I found that both Descent 2 and Carmageddon didn't work (crashed on startup) in DOS using the glide2x.ovl that's packaged with the last official release of the Voodoo 1 Win9x drivers. I had to copy an older glide2x.ovl into the directory of each game to get them to work. I think I used the glide2x.ovl that came with Screamer Rally.
Reply 11 of 35, by kithylin
akula65 wrote:
With regard to Descent II, use the Wayback Machine (http://www.archive.org) to view Dorsola's/KieferSkunk's Descent II 3dfx FAQ […]
Thanks a lot for that info. 😀 Now I just need to get my paws on a voodoo2.
Will a pair of Voodoo 2's run in SLI mode in DOS?
Also, in general what kind of cpu horsepower is required to get decent frame rates with voodoo's in dos? I have a 800mhz AMD Slot-A Athlon for dos gaming right now.
I've been looking for better but it's difficult to find a faster system with an ISA slot. I did some research earlier today for a few hours, the most I could hope for that's even remotely affordable today would be a tyan Socket-462 motherboard that only goes up to 1.4 Ghz AthlonXP's, and even that maybe not.. probably only early Athlons.
I can't find a Socket-370 board that accepts Tualatin P3's @ 1.4 with an ISA slot for < $200. Some folks charge way too much for older hardware today.
The thing is I've been looking for "More" graphically out of some of my favorite dos games for a while but never really figured out the details as to what worked and what didn't. Even with a "Number Nine" PCI video card (or any agp card for that matter), and a 800mhz Slot-A Athlon, it's not enough to do well with VESA modes in dos, still horridly slow 😒
I'm kind of hooked on ISA because I have a nice Creative Sound Blaster AWE-64 Gold + the 28mb creative upgrade card. Which.. sounds awesome for dos games.
Reply 12 of 35, by gulikoza
Some AGP cards were horribly slow in DOS. I think the all-time sweet spot for DOS is ET6000 PCI card + voodoo2. As for CPU horse power anything above 200mhz would be ok. V2 max out at around 450Mhz IIRC.
Reply 14 of 35, by kithylin
See my link above.
I didn't see your link when I wrote that.. nice info to know. I'll have to keep my eyes open for a pair of these sometime soon for my dos gaming machine 😄
Reply 15 of 35, by idspispopd
#9 did make different cards, some with their own chips, some with S3 or other chips. Which chip does your card use? Did you do any benchmarks of transfer performance in VESA modes?
Reply 16 of 35, by kithylin
Mine uses an S3 chip. I can come up with some dos benchmarks, but none of them benchmark "VESA Speed". The most I can come up with is SysChk that does DOS speed period.
Actually, I think SpeedSys does VESA Speed now that I remember.. maybe I need to spend a lot of time today and swap all my cards around and find the fastest one to use.. at least until I get voodoo's.
Reply 18 of 35, by idspispopd
S3 cards are fine. You probably have to some additional utilities: s3vbe20 (unless your card's BIOS already includes VBE 2.0), probably s3spdup and if you want to overclock the card mclk.
I don't know if an equivalent for fastvid might be useful, I couldn't find any, though. (Athlon CPUs do have MTRRs.)
Reply 19 of 35, by kithylin
Davros wrote:
be aware you can also play descent 2 on a modern machine with opengl DXX Rebirth http://www.dxx-rebirth.com/ […]
DXX Rebirth
D2X-XL
http://www.descent2.de/d2x.html
and descent 1
http://www.descent2.de/d2x-descent1.html
That's mostly irrelevant to my situation. Even if I did get that running, the music and sound wouldn't be the same. Part of the entire reason to play Descent 2 (and these other games) in DOS is their usage of my AWE64 video card and the superior sound it produces, when running older games.
So even if I could run any of these games in windows (or even in an emulator) I wouldn't ever desire to do so, as they would use inferior autio in that setup, and most likely run significantly slower vs on a real system in real dos mode.
I have a registered version of SCITECH Display Doctor that can enable VESA modes for a wide variety of video cards. The problem will be discovering which ones are fastest @ VESA Modes for now :> It'll probably be a while until I can get my paws on a voodoo2.
